Offtopic - Kto mi pomoże
magneto - Pią Mar 05, 2010 21:39 Temat postu: Kto mi pomoże Czy ktoś z Was jest użytkownikiem lub jest w posiadaniu w calości albo jakichkolwiek cześci do skutera Peugeot z przelomu lat 50 i 60 minionego stulecia? A może znacie kogos kto ma w posiadaniu taki egzemplarz lub potafi pomóc w znalezieniu cześci? Bardzo proszę o kontakt.
pajda - Pią Mar 05, 2010 23:00
Skuter to Peugeot S 57 B
info
In October 1956 exit of the S 57 B and S 157 B with for modifications the headlight which passes from the apron to the handlebar.
They are provided with a carburettor GURTNER T18 for the 125 Cm3 and T20 for the 150 Cm3. The air filter is more important with a catch D’air on the left side of the hull. The tap D’gasoline becomes accessible by a hearing on the right side from the hull. The saddles are out of rubber identical to Lambretta LD.
Engine 125 Cm3 or 150 Cm3.
2 high-output times in the axis of the frame.
The startup is carried out by a pedal which perhaps easily actuated without leaving the saddle.
Cooling by turbine on magnetic wheel 40 Watts ensuring lighting and lighting.
Central tank carburettor with external air intake filter.
Three speeds per selector ordered by handle with the handlebar.
Selector speeds ordered by handle with the handlebar (with Italian).
2 drum brakes of 130 mm.
Drive Yellow chain 12,7 X 7,9 pennies tight casing.
Body great luxury ensuring a total protection.
Tubular frame.
Case before boltable.
Sight of trunk AV between open. The supèrieure part forms luggage stand. One will notice the hooks for the fastener of the sandows of fixing.
Luggage stand with hooks for the fastener of the sandows of fixing.
Vacuum-pocket with closing of safety.
Boltable glove box (with the same key as that of the theft protection device).
Back hull articulated for access to the engine.
The whole of the body AR can rock around an axis and thus give off all the mechanism. The transmission under tight casing and the powerful turbine of cooling will be noticed.
Standard front suspension tractor drawn by rings Neiman rubber.
Sight of front suspension progressive and car-deadened by rings Neiman rubber.
Suspension AR with oscillating arm rings Neiman rubber.
Handlebar enamelled with built-in headlight.
Sight of the handlebar with enamelled headlight.
Dashboard including/understanding: mileage odometer, orders of the choke, the contact and lighting.
Tank 7 liters.
Great accessibility to the gasoline tank and the candle by the simple swing of saddle AV and the opening of a trap door.
2 saddles with plate rubber.
Broad puts back feet for the passenger.
Handle belt.
Tools, 2 jacks.
Under the frame 4 residences for fixing are laid out of the jacks intended to maintain the scooter at the time of the disassembling of a wheel.
Rear view mirror.
Electric alarm.
Bolt Neiman theft protection device.
Steering lock Neiman combined with hook carry-bag.
Spare wheel.
Sight of the lantern AR embedded in the hub cap of the spare wheel.
Crutch of abutment.
Colour: Ivory or Cream Marly (1957) - Marly Cream or Blue RAF or Red Coral (1958)
Technical data of the engine:
Model
S 57 B
S 157 B
Race
60 mm
60 mm
Boring
51 mm
56 mm
Cubic capacity
123 Cm3
147 Cm3
Compression ratio
6,6 liters
6,6 liters
Advance with lighting
3,5 mm
3,5 mm
Capacity of the tank
0,250 liters
0,250 liters
Gear box
3 ratios
3 ratios
Shifting of speed
with Italian (handle)
Technical data of the frame:
Footing
1,250 m
Overall length
1,830 m
Total width
0,700 m
Height of saddle
0,725 m
Guarantee on the ground
100 mm with passenger
Approximate weight
105 kg
Average consumption
2,3 liters with 45 km/h
Wheels
8 inches
Pressure tire AV (4x8)
solo: 1,5 kg - duet: 1,8 kg
Pressure tire AR (4x8)
Linki http://www.scooterspeugeo...ugeot-s57b.html
http://www.peugeot.com/en...s/scooters.aspx
http://oldtimercentrum.w....estawienie.html
1637. Katalog częsci skutera PEUGEOT S 57 B i S 157 B (j.franc.) 1965r. 40 stron
jest to automobil oldtimer krakowski nr Telefon (012) 266-79-35
Zadzwon moze wypozycza ? dadza zrobic ksero. Tylko, ze to j,francuski, ale dla chcacego nic trudnego
a to jedyne aukcje z ebay-a
http://cgi.ebay.pl/Coque-...=item19b93a3a92
Ten facet sprzedaje duzo czesci do motorow/skuterow. Jest z Francji, wiec pewnie bedzie mial o wiele latwiej dotrzec do czesci.Na ebayu mozesz mu zadac pytanie, pewnie zrozumie po WWE (world wide english )
http://cgi.ebay.pl/Compte...=item3efd8b09ed
http://cgi.ebay.pl/Peugeo...=item3efd7eb9d2
http://cgi.ebay.pl/1958-P...=item3a4f8ab115
Mam nadzieje, ze przyda się ( nota bede 30 min szukania w necie(nawet nie wiedziałem co to za motor przy okazji poznalem kilka skuterkow marki Vespa,Lambretta itd )
magneto - Sob Mar 06, 2010 16:07
Dzieki za linki
