Forum Klubu ROVERki.pl :: Board computer
Board computer
Eny45
Wysłany: Czw Lut 26, 2009 11:49   Board computer
Hello all
I should like introduce to you, Board computer. We make it in Czech Republic. It is someting like a prototip
Mechanism is lightly complicated, but instalation is simply.
It consists of: display from Siemens mobil phone, motherboard with lot of electric parts, programmed microchip, some cables.
How it works?
One cable connect with one injection.
One cable connect with tachometer (speed indicator).
Also need electricity 12V, this can be take from instrument panel.
This is all
When we made the software, we needed lot of information. About injection, and electric pulses from gear box. When is board computer inside the car, user can calibrate them. Computer have a one button, you can adjust exactly number of pulses for speed (for example one car have 15" wheel, another 17" = 6% diferent speed), also can be change the injection data.
First car with this computer is Rover 400 1,6i. This car belongs to MR. Fujitsu. He tested the fuel consumption. He tankful, drive 500km, and tank petrol again. The computer shows him 6,7. And real consumption has been 6,9. He used the options and lightly changed the injection data.
Injection data, or speed data can be change from 0 to 50. And default is 35.
Motherboard is small (7x10x3 cm) MR. Fujitsu hide motherboard behind the instrument panel.
Board computer have a few functions. Display can shows you:
1) momental petrol consumption and momental speed.
2) today distance moved and consumption for lap of the journey (example 28litres/400km)
3) average consumption and accumulator voltage
All of screens can by change over by button. Today distance moved, consumption for lap and average consumption can be reset by button too.
Here is some fotos:
Ostatnio zmieniony przez Eny45 Czw Lut 26, 2009 12:33, w całości zmieniany 2 razy
Wysłany: Czw Lut 26, 2009 11:49   Post o charakterze reklamowym. Każde Twoje kliknięcie zwiększa nasze szanse przeżycia ;)
jasiu87
Wysłany: Czw Lut 26, 2009 12:26
i can se only one picture :( can u host on other server ?
Eny45
Wysłany: Czw Lut 26, 2009 12:33
the same fotos
http://eni.wz.cz/22.jpg
http://eni.wz.cz/23.jpg
http://eni.wz.cz/24.jpg
http://eni.wz.cz/25.jpg
http://eni.wz.cz/26.jpg
Marrkus
Wysłany: Czw Lut 26, 2009 21:04
Wygląda dobrze o wiele lepiej niż projekt z Elektroniki Praktycznej przedstawiony tu:
http://www.roverki.pl/article.php?sid=446
Nie ma takiego natłoku informacji i jest o wiele czytelniejszy czytelniejszy.
matlacz
Wysłany: Pią Lut 27, 2009 08:53
NIe znam za bardzo się na angielskim większość zrozumiałem. Ale chyba nie pisze czy to nadaje się do diesla?
Eny45
Wysłany: Pią Lut 27, 2009 10:00
I understant only half, of all you say :neutral: , but this is only for benzín - petrol motor. Diesel have very diferent injection.
In this time, we make 4 another board computer. And i hope we can show you instalation in another rover 400 and 45.
and here is some more fotos from rover 400
http://www.fuji.estranky....itac/original/8
http://www.fuji.estranky....tac/original/12
fearless
Wysłany: Pią Lut 27, 2009 12:47
To jak można się w to zaopatrzeć ??
dobryziom
Rover Coupe
Wysłany: Pią Lut 27, 2009 13:01
mnie by interesowało czy podejdzie to do mojego 220 turbo (bo często nam problem z obliczeniem trasy i wirem w baku ) i jak z wysyłka i najważniejsze koszt?
Tomcata na części info na PW
Wysłany: Sob Lut 28, 2009 11:09
Piszmy po angielsku, kolega może nie rozkminiac polskiego :razz:
Hi,
I've got a little question, does this copmuter works with another Rovers or only with 400/45? I've got Rover 216 Coupe from 1996 with Honda engine- d16A8. Will your computer work with my engine and with another Rover engines?
How much is it? How with sending it to Poland??
Botanix
Wysłany: Sob Lut 28, 2009 14:55
Very interesting and usefull gadget but I am looking for diesel one. Many of us would like to know how much would it cost to send them to Poland. Probably it would be much cheaper if we buy them wholesale. I mean 10-20 items at once. So we would like to know:
1. How much for 1 item ( item cost + dispatch to Poland and England - one for me :) )
2. How much for 10 items.
3. Any ideas wher to fit it on dashboard?
4. Which models are compatibile with your device?
5. When if whenever we can expext devices suitable for diesel engines?
6. Where to buy and how to make a payment?
Regards
Polska wersja:
Bardzo interesujący i użyteczny gadżet ale szukam takiego dla diesla. Wielu z nas chciałoby się dowiedzieć ile kosztowała by wysyłka do Polski. Prawdopodobnie byłoby taniej jeśli zakupimy je hurtowo. Mam na myśli 10-20 sztuk za jednym razem. Chcielibyśmy więc wiedzieć:
1. Ile za wysyłkę jednego przedmiotu ( koszt przedmiotu + wysyłka do Polski i do Anglii - jeden dla mnie :) )
2. Ile za 10 sztuk.
3. Jakieś pomysły gdzie umieścić to na desce rozdzielczej?
4. Które modele są kompatybilne z Twoim urządzeniem.
5. Kiedy, jeśli kiedykolwiek możemy spodziewać się urządzeń nadających się dla silników diesel?
6. Gdzie kupić i jak dokonać płatności?
Pozdrowienia
[ Dodano: Sob Lut 28, 2009 14:58 ]
Forget about 3rd question, I found an answer in your previous post.
Polska wersja:
Zapomnij o 3 pytaniu, znalazłem odpowiedź w Twoim poprzednim poście.
reservasjonerb
est deals
truten23
Wysłany: Sob Lut 28, 2009 22:40
Hmm, wery interesning gadget for R400... :hm:
Botanix napisał/a:
I too :wink:
giewu
Wysłany: Sob Lut 28, 2009 22:51
Markzo napisał/a:
... kolega może nie rozkminiac polskiego :razz:
a Ty w to wierzysz ? :mrgreen: :rotfl:
Homi
Wysłany: Sob Lut 28, 2009 23:32
Please answer Markzo, question. I would like to know if it works with my 1.4 16V K-series engine in Rover 200 '97.
Eny45
Wysłany: Pon Mar 02, 2009 10:47
Hello
Give me som time, I answer all question.
- First this board computer can be uset in 1,4 1,6 and 1,8 16VRover motor.
- other motor, like Honda is problem. This car have propably Honda transmission. This all is too diferent. (but I tolk my friend, I let you know)
- Instalation in rover 200/25 maybe like this foto1 foto2
- this not work with Diesel engine (but I tolk my friend, I let you know)
- send this to Poland is not problem. I have one Frend, he work in Poland in Walbrzych.
- England is not problem. Bud you must pay before we send it.
- price, I dont now :) Bud I let you know soon
[ Added: Mon Mar 02, 2009 11:28 ]
- For Honda motor we need know type of injection. And who manufactured this Injection.
After we can change software.
- I know exact price during 1 - 2 weeks. But can be 110 - 180 Euro for one board computer. When we make 10 computer, the price can be 10 euros lower. (100-170)
We make this with own hans, and for one board computer need 10 - 15 hours work, and many material.
I let you know exact price.
BoloSr
Wysłany: Pon Mar 02, 2009 18:15
fajne tylko ta cena zabija :roll:
Wysłany: Pon Mar 02, 2009 19:10
it's quite expensive...too expensive :/ http://www.allegro.pl/ite...zdego_auta.html
here is board computer, it is available on www.allegro.pl for "only" 20,95 Euro. And it has got more useful functions the Yours :/ price like 30-40 euro is allright, but 110-180 is definitely to much.
Tak BTW, jakby tego kompa z allegro ożenić z jakimś ładnym wyświetlaczem to chyba zadziała co? taki jakiś co by do Roverka pasował i jego program i fajny gadżet za 99zł... to 110-180euro to przesada!
torez
Wysłany: Pon Mar 02, 2009 21:50
Markzo napisał/a:
Hello, Yes the price is too high but I can read on tthe web site http://vita-v.blog.cz/070...ubniho-pocitace or http://www.hyundaiclub.ne...=1898&start=195 only 90€ or 2500CZ
Wysłany: Pon Mar 02, 2009 22:26
Hi :smile:
I think it is still too expensive...yes, it looks nice, but we can buy sth like I showed before and it costs only 20euros :wink: If you want us to buy your board computer, you have to be more competitive :wink: and if we'd have troubles with your appliance, we'd also have troubles with fixing it in Poland....we probably have to send it back to You and it is costly :/
dobryziom
Rover Coupe
Wysłany: Wto Mar 03, 2009 00:10
czy tylko ja mam takie wrazenie ze ten ekranik wyglada w tym miejscu gorzej niz obciachowo i amatorsko?
Botanix
Wysłany: Wto Mar 03, 2009 01:02
Nie tylko Ty... w R200 jest nieco za mało miejsca na taki ekranik, daltego wczśniej spytałem jak to montować :???:
Poza tym za 500zł to i można kupić N70 ( nokie ) rozmontować, napisać program na symbian, który policzy 100 razy więcej niż te zabawki, wmontować kolorowy ekran i to dopiero byłby bajer :) .
Hmm w sumie nie najgłupszy pomysł :)
