[Mg zr]Problem z zapalniczka
Autor
Wiadomość
Kaczorinho
Wysłany: Sob Sty 23, 2016 11:29 [Mg zr]Problem z zapalniczka
Rodzaj silnika : benzyna Pojemnosc silnika : 1.4 16v Rok produkcji : 2002
Witam moim problemem jest niedziałająca zapalniczka, nawiew działa. Ktory bezpiecznik w kabinie odpowiada za zapalniczke
Wysłany: Sob Sty 23, 2016 11:29 Post o charakterze reklamowym. Każde Twoje kliknięcie zwiększa nasze szanse przeżycia ;)
NoPE
Pomógł: 51 razy Dołączył: 12 Lis 2012 Posty: 1422 MG ZR
Wysłany: Nie Sty 24, 2016 16:22
Here's a diagram showing which fuse and Relay is located where. These diagrams and locations are taken straight from AutoData so not all fuses here will be on your car.
Interior Fusebox
F1 (10A) - Hazard Warning Lamps, Clock, Instrument Cluster, Automatic Transmission (AT)
F2 (10A) - Anti-lock Braking System (ABS)
F3 (10A) - Interior Lamps, Data Link Connector (DLC), Instrument Panel, Audio System Clock
F4 (10A) - Instrument Panel, RH Headlamp - High Beam
F5 (10A) - LH Headlamp - High Beam
F6 (25A) - Sunroof Motor Relay
F7 (5A) - SRS Control Module
F8 (10A) - Instrument Panel, Heated Rear Window, Headlamp Adjustment, LH Tail Lamp, Audio System, Multifunction Control Module, Glovebox Lamp, Front Fog Lamps, LH Side Lamp
F9 (10A) - Multifunction Control Module
F10 (10A) - LH Headlamp - Dip Beam
F11 (10A) - RH Headlamp - Dip Beam
F12 (10A) - RH Side Lamp, RH Tail Lamp, Headlamp Adjustment - RH, Licence Plate Lamps
F13 (15A) - Windscreen Wipers
F14 (10A) - Engine Coolant Blower Motor, Engine Control Module (ECM), Alarm System Control Module, AC/Heater Blower Motor, Cigarette Lighter Relay
F15 (15A) - Heated Winscreen Jets, Rear Screen Wash/Wipe System, Air Conditioning (AC)
F16 (10A) - Brake Pedal Position (BBP) Switch, Reversing Lamp
F17 (10A) - Multifunction Control Module, Audio System
F18 (7.5A) - Electric Door Mirrors, Alternator, Door Mirror Control Module (Diesel), Transmission Vehicle Speed Sensor (Automatic Gearbox)
F19 - ...
F20 (10A) - Ignition Switch
F21 (20A) - Electric Windows Control Module, Electric Window Switch - Left Front
F22 (20A) - Electric Window Switch - Right Front
F23 (25A) - Heated Rear Window
F24 (15A) - Multifunction Control Module
F25 (10A) - Daytime Running Lamps
F26 (20A) - Headlamp Washer Pump Relay
F27 (10A) - ...
F28 (10A) - ...
F29 (10A) - Daytime Running Lamps
F30 - ...
F31 (15A) - Rear Electric Windows - RH
F32 (15A) - Rear Electric Windows - LH
1 - Indicator/Hazard lights Relay
2 - Heated Rear Window Relay
3 - Multifunction Control Module
Engine Bay Fusebox
F1 (150A) - Alternator, Engine Control (EC) Relay
F2 (40A) - Ignition Switch
F3 (40A) - Ignition Switch
F4 (40A) - Electric Window Relay, Interior Fusebox/Relay Plate
F5 (40A) - ...
F6 (80A) - Glowplug Relay (Diesel)
F7 (40A) - Starter Motor Relay, Interior Fusebox/Relay Plate
F8 (20A) - AC Condensor Blower Motor Relay, Fuel Pump Relay, Engine Coolant Blower Motor.
F9 (40A ) - Light Switch, Daytime Running Lamps
F10 (30A) - AC/Heater Blower Motor, Cigarette Lighter Relay
F11 (40A) - Engine Coolant Blower Motor Relay
F12 (40A) - ABS Control Module
F13 (10A) Diesel - Exhaust Gas Recirculation (EGR) Solenoid, Mass Air Flow (MAF) Sensor, Heated Oxygen Sensor (HO2S), Vehicle Speed Sensor
F13 (10A) Petrol - Evaporative Emission (EVAP) Canister Purge Valve, Heated Oxygen Sensor (HO2S)
F14 (20A) Diesel - Injection Pump Assembly, Engine Control Module (ECM).
F14 (20A) Petrol - Injectors, Engine Control Module (ECM), Camshaft Position (CMP) Actuators, Ignition Coils.
F15 (10A) Diesel - Glowplug Relay
F15 (10A) Petrol - Heated Oxygen Sensor (HO2S), Camshaft Position Sensor
F16 (10A) - AC Condensor Blower Motor Relay
F17 (15A) - Alarm System Control Module, Alarm System Horn Relay
F18 (15A) - Fog Lamp Relay
F19 (15A) - Hazard Warning Lamps Switch
F20 (15A) - Engine Control Module (ECM)
F21 (10A) - AC Relay
F22 (20A) - Inertia Fuel Shut-off (IFS) Switch
1 - Fuel Pump Relay
2 - Starter Motor Relay
3 - Engine Coolant Blower Motor Relay (1)
4 - Engine Control (EC) Relay
5 - Heater Blower Relay
6 - Fog Lamps Relay
7 - AC Compressor Clutch Relay
Źródło
_________________ Jak Kolonko, mówię jak jest.
Temat
Autor
Forum
Odpowiedzi
Ostatni post
[R200Si] Problem z zapalniczka
rucio
Rover serii 200/25, MG ZR i Streetwise
13
Sob Paź 04, 2008 22:08 leszek95b
[R200 1.6 96]Zapalniczka nie odskakuje
TheArt
5
Nie Maj 23, 2010 16:51 staf
[R25] zapalniczka i rozgalezniacz jak podlaczyc
Sylwek1
7
Pią Mar 02, 2012 18:50 tuners
[R200 '97 1.4 16V] Nie działa zapalniczka (gniazdo 12V)
bezpiecznik?
Homi
11
Sro Gru 31, 2008 23:16 coldmanns
[R200 R25 ZR] - Nie działa zapalniczka i nawiew
HuMaX
14
Pią Sty 06, 2017 18:19 mirko64
