Forum Klubu ROVERki.pl :: [R75/ZT] - TOAF Diagnostic Tool
Temat dotyczący programu TOAF, narzędzia diagnostycznego dla samochodów marki Rover 75/MG ZT
fredup
Wysłany: Nie Sty 15, 2017 11:03
Would it be possible to have cruise control come on at 20mph instead of 22mph which it is as standard?
20mph zones are increasing in the UK and are in force around all the schools.
Have you looked into MAF delete also?
Wysłany: Nie Sty 15, 2017 11:03   Post o charakterze reklamowym. Każde Twoje kliknięcie zwiększa nasze szanse przeżycia ;)
MaReK
Instytucja wspierająca
Pan
Wszechomogący :)
MG ZT
Wysłany: Nie Sty 15, 2017 11:57
fredup napisał/a:
I never thought about the change in the minimum speed for the cruise control. I do not know if it's possible. I will check.
fredup napisał/a:
What does it mean to delte MAF? You mean no fault in ECU after it was disconnected?
dolny śląsk:marcin.misek
wielkopolska: longer86
fredup
Wysłany: Nie Sty 15, 2017 15:49
MaReK napisał/a:
fredup napisał/a:
fredup napisał/a:
We all know that you can disconnect the MAF sensor and it will then run with default settings. Someone has worked out a way so that the the MAF can be deleted for the better and save the £120 for a new one.
Not here to witter on about the mafless patches so I'll try and limit it to a couple of sentences - at the factory fuel is limited by the mass air flow signal for smoke limitation reasons, the more airflow detected, the higher proportion of your throttle position is considered 'valid' for fuel delivery. My tweak substitutes the signal for the MAP sensor (boost pressure) - fuel is still limited based on boost (and thus airflow indirectly) but the pressure sensor is far more reliable in the long term (almost 100%).
Sometimes people ask why they don't use this method from the factory, two answers - the first is that they did, and still do in some cases - the second and more boring answer is that for a while manufacturers preferred maf signals as they respond a bit quicker and so easier to work with when making low emissions calibrations. These advantages don't really manifest into anything concrete outside the calibration and emission testing world, and almost all turbo conversions I do map will end up running on map based calibration even if not as stock.
Wysłany: Nie Sty 15, 2017 15:56
There are two maps in ECU one is map about what engine need to work properly, and the second map is about fuel quantity in relation to mass air flow.
When MAF is disconnected then ECU use default value.
You can find map you need and then set all fuel values in specific range you want.
75 Red Edition
Wysłany: Nie Sty 15, 2017 17:18
fredup napisał/a:
Correct me if I'm wrong, but it's in the cruise control unit that is not programmed using OBD, at least by now.
Wysłany: Nie Sty 15, 2017 17:55
I haven't got cruise control, but I don't even mind to use it on city roads with such low speeds. Cruise control is good on motorway ;)
75 Red Edition
prebenny
Wysłany: Nie Sty 15, 2017 18:01
longer86 it's useful driving 40 km/h behind 120 y.o. grandfather who's driving from church at sunday and it's impossible to pass him. No need to operate gas pedal = less stress :lol:
fredup
Wysłany: Nie Sty 15, 2017 19:54
longer86 napisał/a:
We have speed cameras,and camera vans, and police by the roadside with speed guns. In the UK it's too easy to get caught speeding so we use cruise control nearly all the time especially around town to stop people from pushing us over the speed limit. To be able to set it at 20mph would be really useful.
Marcin84
Wysłany: Pon Sty 16, 2017 12:32
marcin.misek napisał/a:
longer86 napisał/a:
Nie zaglądałem, ale stawiam ze to pliki do postawienia lsm na nogi kiedy nie uda sie aktywować drl
A dokładniej pliki standardowe, pozwalają na odzyskanie świateł pozycyjnych...
Chociaz do dzis dnia nie wiem jak to sie wywala.. mi sie nie udalo
Z tego co pamiętam to mam w garażu moduł z wywalonymi światłami pozycyjnymi jakby co :)
Rover 600SDi, Rover 75 2.0 CDT, Rover 75 1.8T
jmierzwa952
Wysłany: Pon Sty 16, 2017 21:26
Czy po zakupie tableta takiego jak dawidd, podczas jazdy mozna podgladac parametry pracy silnika itp?
Silnik 2,0 v6 automat :P
Punx
Wysłany: Pon Sty 16, 2017 21:31
Można, ale to proszenie się o kłopoty bez odpowiedniego przeprowadzenia kabla tak aby się pod nogami nie majtau ...
Sa rozdzielacze do OBD np.:
http://www.tuningobd.com/...DO/GNIAZDA/OBD2
jmierzwa952
Wysłany: Pon Sty 16, 2017 21:37
a czy moze wiesz dokladnie które parametry wejsc zeby to widziec?
https://www.youtube.com/watch?v=hib4pUyUbks
a co sadzicie o tym?
Punx
Wysłany: Pon Sty 16, 2017 21:46
Jak chcesz takie wodotryski to zainstaloj Torque Pro/Lite i lacz sie po BT unikniesz kabli pod nogami a i wizualizacja/prezentacja danych bedzie ciekawsza.
Toaf jest przeznaczony do diagnostyki, ale owszem czasami przydaje sie diagnozowac auto w ruchu ... myslalem ze o to pytasz.
jmierzwa952
Wysłany: Pon Sty 16, 2017 21:55
a ktos testował coś takiego?
a co do ceny jak to sie prezentuje?
MaReK
Pan
Wszechomogący :)
MG ZT
Wysłany: Pon Sty 16, 2017 23:25
Ale nie ma w TOAFie live daty do v6 ;/
dawidd
Wysłany: Wto Sty 17, 2017 05:14
Ją testowałem torque pro na bt, ale w dieslu. Chodzi ok, ale wielu parametrów nie zobaczysz. U mnie było temp silnika, ciśnienie doładowania, obroty, położenie gazu i coś tam jeszcze. Mnustwo parametrów które oferuje program nie dzialalo
WileECoyot
Wysłany: Sob Sty 21, 2017 13:39
Pytanie za sto punktów, nie dostrzegłem nigdzie instrukcji do TOAF ( obsługi programu), czy ktoś mi podpowie w którym miejscu mogę podejrzeć aktualne odczyty z livedata tak abym zobaczył jak pracuje turbina wtryski itp? Czy takiej możliwości w TOAF nie ma.
arekqq
Wysłany: Sob Sty 21, 2017 15:01
https://forum.roverki.eu/viewtopic.php?p=916234&highlight=#916234
jmierzwa952
Wysłany: Czw Sty 26, 2017 21:08
czy jest szansa na pojawienie sie live data do v6 i jakiejs nowszej wersji oprogramowania do silnika?
[ Dodano: Czw Sty 26, 2017 21:08 ]
Prosze o poradę w związku z Toafem, po wejsciu w kodowanie bodajze SRS, w zakladce pozostałe jest parametr kontolka sygnalizujaca i mam nieaktywny, moze ktos wyjasnik o co chodzi w tym?
marcin.misek
Profesor
Coding Group
Wysłany: Pią Sty 27, 2017 16:07
jmierzwa952 napisał/a:
Ale.. czego wlasciwie oczekujesz ?
Mowiec szczerze.. jesli wszystko działa to nie ruszałbym nic.
A do czego konkretnie jest ta opcja.. to i ja dokladnie nie wiem.
Podobne sterowniki byly w BMW wiec mozliwe ze ta opcja nie jest obslugiwana przez Rover/MG
Kodowanie, diagnoza R75/MG ZT
Dopisywanie kluczy, pilotów
Brak nowych postów [R75] Toaf Tool Chip Tuning - CDT -> CDTI
MATRIXorg Rover serii 75, MG ZT 21 Pon Lut 25, 2019 12:33
MaReK
Brak nowych postów [MG ZT CDTI 2.0 ]PODNIESIENIE MOCY PROGRAMEM TOAF TOOL
88Belfegor Rover serii 75, MG ZT 1 Czw Sty 27, 2022 22:12
MaReK
Brak nowych postów [R75]TOAF
grota10 Rover serii 75, MG ZT 6 Sro Sie 09, 2023 20:16
marcin.misek
Brak nowych postów [R75]Toaf
Dargor Rover serii 75, MG ZT 4 Sob Gru 09, 2017 21:06
Dargor
Brak nowych postów [R75] Pomoc z Toaf'em
itemek48 Rover serii 75, MG ZT 34 Sro Mar 23, 2022 23:58
MaReK
