Forum Klubu ROVERki.pl :: [R200] Angielski tech. prośba o przetłumaczenie paru zdań.
Saaphyri
Wysłany: Pią Lut 03, 2017 12:45   [R200] Angielski tech. prośba o przetłumaczenie paru zdań.
1.
Acces 2 right lower manifold bolts with 1/4" in drive, 8 in extension throught direction of arrow. Just enough space between inlet pipes.
2.
Remove 2 x 13mm mounting bolts to allow the exhaust manifold to pull back. When replacing put these bolts in loosely before manifold bolts
3. [quote] M
ove underneath the car. Remove stay bar bolt.
Loosen rear bolt ( No need to remove ) to free stay
4.
Jack the engine up under sump ( Use wood on jack ). Jack engine up slightly.
2x18mm
15mm bolts
15mm nuts
Rotate the bar upwards out of the way
5.
Back underneath, 13mm bolt on power steering tensioner. Rotate clockwise and remove belt
6.
It will be easier to acces these bolts with the engine jacked up
7.
Turn cams to align both marks
8.
Loosen these bolts so you can pull cam cover out.
Make your own crank pulley mark
9.
Loosen tensioner bolt and remove belt. The cams may move at this stage which isn't a problem as long as you've marked the pulleys.
If the crank moves then this is also ok as long as you've already marked its position
10.
Carefully lossen the head bolts in the order show. Use an E14 socket and ensure that you keep the socket upright as the bolt round easily.
You will need to turn the cams slightly to get your socket past webbing on the cams ( Circled ).
11.
Remove cam bolts. 17mm socket on T-Bar. Give the T-Bar a good clouth anti-clockwise with a hammer to shock the bolts loose.
12.
Slightly lift the head off 2 dowels, slide bacwards slightly and you can lift the head off
13.
Block cleaned. I use break cleaner and wire brush on power drill to clean. Clean the head to the same standard.
Important: Its essential not to turn the engine over at this stage as you may unseat the cylinde liner's.
14.
New Gasket and dowels. This is the part 3 steel gasket with a separate shim gasket that goes between the head gasket and block.
15.
Dowels installed. Note that these are a tight fit. Tap in lightly with wooden block. Note that there are 2 dowels, one either end of block.
16.
New headgasket - Note marking.
17.
After fitting cam belt turn throught 2 compete turns and ensure that the marks still line up.
Seal cam cover with a thin bead of silicon sealant.
Remember to make sure al tools and remove before starting.
______________________
Zdania pochodzą z filmu: Rover 200 Head Gasket Removal.
https://www.youtube.com/watch?v=B1aKBYiDbiI
Pozdrawiam.
Wysłany: Pią Lut 03, 2017 12:45   Post o charakterze reklamowym. Każde Twoje kliknięcie zwiększa nasze szanse przeżycia ;)
Wysłany: Pią Lut 03, 2017 15:55
https://translate.google.pl/ ;)
75 Red Edition
NoPE
MG ZR
Wysłany: Nie Lut 05, 2017 22:18
17.
Po zamontowaniu paska rozrządu wykonaj 2 pełne obroty* i upewnij się, że znaczniki* są wciąż w linii.
Uszczelnij pokrywę zaworów cienką warstwą uszczelniacza silikonowego.
Remember to make sure al tools and remove before starting <- zdanie bzdura. Źle zacytowane. Popraw.
* pewnie wałem korbowym
** na kołach pasowych
16.
Nowa uszczelka pod głowice - zwróć uwagę na znacznik*
*pewnie kierunek montażu
15
Kołki (tut. ustalające tulejki) zamontowane. Zauważ, że są ciasno pasowane. Stuknij lekko przez drewniany klocek. Zauważ, że są 2 kołki po bokach/na końcach bloku.
14.
Nowa uszczelka i kołki ustalające. To jest 3 częściowa stalowa uszczelka z osobną warstwą (podkładka), która idzie między uszczelkę głowicy a blok.
13.
Blok wyczyszczony. Do czyszczenia używam zmywacza do hamulców i szczotki drucianej do wiertarki. Wyczyść głowicę do takiego stanu* (*jak pokazano na zdjęciu czy filmie)
Ważne: Istotne by nie kręcić silnikiem na tym etapie jako, że możesz naruszyć tuleje cylindra.
12.
Póżniej.
PS. Skąd masz opis - będzie mi łatwiej tłumaczyć bo nie znam kontekstu
Jak Kolonko, mówię jak jest.
columbus73
Wysłany: Nie Lut 05, 2017 23:47
17.
Remember to make sure...
Upewnij się że pozbierałeś wszystkie graty, klucze , kubek z kawa, puszki po piwie telefon ,naleśniki i szalik z komory silnika zanim odpalisz silnik .
Aby nasze życie było twórcze, musimy pozbyć się lęku przed popełnieniem błędu
Krzysztof 605059876
Saaphyri
Wysłany: Pon Lut 06, 2017 13:12
NoPE, Zdania pochodzą z filmu: Rover 200 Head Gasket Removal.
Brak nowych postów [R ALL] prośba o pomoc
beowulfe Wszystkie (Wszystkie modele marki Rover i MG) 1 Nie Kwi 24, 2011 13:51
adamsky
Brak nowych postów [R all ]prosba o dane z rava...
Gość Wszystkie (Wszystkie modele marki Rover i MG) 2 Pon Kwi 23, 2007 14:59
GreenApple
Brak nowych postów [All]Prośba o pomoc w identyfikacji silnika
marcij Wszystkie (Wszystkie modele marki Rover i MG) 9 Pią Mar 11, 2011 20:25
Tomek1212
Brak nowych postów [Rover] Prośba o pomoc w identyfikacji silnika.
choli2 Wszystkie (Wszystkie modele marki Rover i MG) 5 Pią Kwi 05, 2013 21:21
choli2
Brak nowych postów [k series] Prośba o sprawdzenie maksymalnych obrotów
ADI-mistrzu Wszystkie (Wszystkie modele marki Rover i MG) 5 Nie Lis 07, 2010 12:03
