Forum Klubu ROVERki.pl :: [R75] Pinout Ecu silnika
vwjacek
Wysłany: Wto Sty 31, 2012 09:37   [R75] Pinout Ecu silnika
witam czy dysponuje ktoś takim schematem? przeglądałe materiały na forum ale niestety nie potrafie tego znaleść.
Ostatnio zmieniony przez apples Sob Lut 11, 2012 08:27, w całości zmieniany 1 raz
Wysłany: Wto Sty 31, 2012 09:37   Post o charakterze reklamowym. Każde Twoje kliknięcie zwiększa nasze szanse przeżycia ;)
Wysłany: Wto Sty 31, 2012 12:30
czy o to chodzi :
ECM harness connector pin details
Pin No. Description Input/Output
1 Ignition coil No. 4 Output
2 Ignition coil No. 3 Output
3 ECM earth Input
4 EVAP canister purge valve Output
5 Not used -6
Not used -7
Main relay Output
8 VIS valve - balance - signal Output
9 Fuel pump relay Output
10 Activate cruise control Output
11 Not used -12
IAT/MAP sensor Input
13 HO2S - rear bank - sensor output Input
14 HO2S - front bank - sensor output Input
15 ECT sensor Input
16 Not used -17
VIS valve - balance - position feedback Input
18 Crankshaft position sensor earth Input
19 Camshaft position sensor earth Input
20 Knock sensor signal (1) Input
21 Vehicle speed Input
22 PAS switch Input
23 VIS valve - connect - position feedback Input
24 Not used -25
A/C trinary switch (low and high switches) Input
26 Not used -27
CAN bus high Input/Output
28 ECM earth Input
29 Direct battery feed Input
30 Direct battery feed Input
31 Ignition coil No. 6 Output
32 Ignition coil No. 5 Output
33 Earth Input
34 Not used Output
35 Not used -t
36 HO2S heater - front bank Output
37 Not used -38
VIS valve - connect Input
39 Cooling fan relay (1) Output
40 Not used -41
Not used -42
Idle air control (IAC) valve Output
43 Not used -44
Throttle position feedback Analogue/input
45 ECT Input
46 Not used -47
48 Fan coolant temperature Input
49 A/C trinary switch (medium switch) Input
50 Knock sensor (2) Input
51 Not used -52
Immobilisation ECU Input
53 Fan coolant temperature Input
54 CKP sensor signal Input
55 Not used -56
Diagnostic ISO 9141-2 K line Input/Output
57 CAN bus low Input/Output
58 Fuel injector cyl 4 Output
59 Fuel injector cyl 2 Output
60 Fuel injector cyl 1 Output
61 Ignition coil No. 1 Output
62 Ignition coil No. 2 Output
63 Earth Input
64 Air conditioning relay Output
65 HO2S heater - rear bank Output
66 Battery voltage from main relay Input
67 Earth Input
68 Cooling fan relay (2) Output
69 Cooling fan relay (3) Digital/output
70 IAC valve stepper motor step 2 Output
71 IAC valve stepper motor step 1 Output
72 IAC valve stepper motor step 4 Output
73 IAT/MAP sensor Input
74 Throttle position sensor Output
75 Throttle position sensor Input
76 Not used -77
HO2S - front and rear bank - heater earth Input
78 IAT/MAP sensor Output
79 Not used -80
Knock sensor (1 and 2) Input
81 Not used -82
CMP sensor signal Input
83 Not used -84
Diagnostic connector Input
85 Not used Input
86 Flash programming Input
87 Not used -88
Fuel injector cyl 3 Output
89 Fuel injector cyl 5 Output
90 Fuel injector cyl 6 Output
Andrzej
vwjacek
Wysłany: Wto Sty 31, 2012 19:44
dziękuje bardzo o to właśnie mi chodziło :wink:
Brak nowych postów [R75] pinout zegarów
sash997 Rover serii 75, MG ZT 10 Pią Lut 07, 2025 18:00
marcin.misek
Brak nowych postów [R75] Para spod silnika, wariująca temperatura silnika
bujak19 Rover serii 75, MG ZT 10 Pią Sty 30, 2009 17:40
bujak19
Brak nowych postów [R75]Dziwna praca silnika i jej zmiana po zgaszeniu silnika
marecki6 Rover serii 75, MG ZT 5 Sro Cze 08, 2016 09:53
Brak nowych postów [R75] Zła praca silnika, niskie obroty silnika
boomi19lca Rover serii 75, MG ZT 20 Czw Gru 22, 2011 15:51
joannak25
Brak nowych postów [R75] KOD SILNIKA
grzegorz1975 Rover serii 75, MG ZT 2 Sro Lut 01, 2017 11:22
grzegorz1975
